11 members (Buckeye998, treegrower, carbking, dt235sd, Phak1, Rusty Rod, Gdads51, Bill Hanlon, 68ironhead, GMCJammer51, 1 invisible),
379
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Hi,All! A friend gave me a Rochester B,since mine had a stuck "BB",in the fuel discharge. This came off a '54 2-ton 6500,with a ' 261,B.T.W. I got it torn-down,and let it soak over the week-end. Today,I re-built it. When I tried to put the base gasket on my intake,the bolts were off about 1/4 inch! Spread was shorter than intake on my '55 261. I tried the "new" carb,without the gasket-SAME thing! I swapped the lower part,(throttle body),and it bolted right up. I just cleaned the original base gasket good,and dumped some gas in the carb.,to prime the pump. Started right up-every time,but no gas to carb-1/2-full tank! Ran the battery dead,trying to get gas to the carb! flipped the seat forward,and-LOOKY HERE! I forgot to hook the fuel line back up from the pick-up tube!! L.O.L. Maybe,if I get all my ducks in a row,I'll have this thing running tomorrow?? If you can't laugh at your mistakes,don't make any! Me?...I'm laughing all the time!! Have a GREAT day!!
| | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Nice try.....you know somebody needs to keep verifying that motors still don't run on air alone. Thanks for checking. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I,ve got some kind of blockage in my tank. I took it out this Spring,to freshen it up a bit,before installing a new wiring harness. I connected all of the lines,(today),but still no fuel! I replaced the 5" cab-to-frame line,and blew-out the frame-to pump line. It seemed constricted,so I'm going to replace that line,as well. I was getting some fuel,at initial start-up,but then...not a drop. With 10 gallons in the tank,you'd think the gas would "siphon".but only got a drop or two,at the pump feed line. Same story at the tank outlet,(bottom of P.S. cab). That's what makes me believe I have some kind of blockage in the tank itself! I had the filler neck plugged,while in storage,but,there's got to be a reason! I'll let you know what I find out tomorrow. Probably in for another good laugh! B.T.W...For the short period of time the engine was running,I could sure tell the difference in the carb. already! I haven't even got it adjusted yet,and it IDLES!! One down,??? to go??
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I wouldn't run it until you take a look inside the gas tank so you don't plug up another carb. I'd take the fuel sender out and take a look with a flashlight. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks,Don! that's the plan,exactly!! | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | | | |
