2 members (55shaker, Stovebolt48), 118 guests, and 5 robots.
Topics128,187
Posts1,057,313
Members48,468
dww
Offline
I am rebuilding a 1950 3100 chevy truck, and am working on the brake
& clutch pedal.
I bought the new bushing for the shaft pivot arm from Jim Carter,
but the shaft has steps worn in it.
Does any one make a replacement shaft, for this PROBLEM, can you help?
1950 3100 1/2 ton owned sense 1972
I would put a post in parts wanted section and get a replacement there are alot of bare frames out there that have good ones on them,I had one but gave it to a father and son that were going to build a truck.
Pete
Welcome to the stovebolt.
I may be able to help. PM sent
Had the same problem... took the pedal assembly completely apart, welded up the worn areas on the pins (watch your HEAT! they're hollow!), turned them down in a lathe, reinstalled with new bushings. Like new again!
Greg
