0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1052948 08/31/2014 1:58 AM
Does any one know how to replace or build new front upper shock mounts for the 58?
if you mean the odd shaped piece riveted to the frame that sometimes gets ripped loose .... no, you need to find one from a donor frame and bolt it on after cutting off the old rivets and repairing any tears on the frame
if you mean just the 'pin' that the shock eye mounts on, replace it with a grade 8 bolt .... and make sure you have good springs and the correct shocks so it doesn't get mangled again
Red, Thanks for the response. I have broken upper front shock mounts, a better question is 'are there any replacement mounts out there' or is it find a donor and use that?
as I said, depends on just what's 'broken', but yes, you'll be looking for a donor or a bolt, there aren't any repros that I know of - some new shocks come with a replacement mounting stud if the riveted on mount plate is OK
