1 members (JW51),
137
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 14 New Guy | | New Guy Joined: Nov 2009 Posts: 14 | Does any one know how to replace or build new front upper shock mounts for the 58? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you mean the odd shaped piece riveted to the frame that sometimes gets ripped loose .... no, you need to find one from a donor frame and bolt it on after cutting off the old rivets and repairing any tears on the frame
if you mean just the 'pin' that the shock eye mounts on, replace it with a grade 8 bolt .... and make sure you have good springs and the correct shocks so it doesn't get mangled again
Bill | | | | | Joined: Nov 2009 Posts: 14 New Guy | | New Guy Joined: Nov 2009 Posts: 14 | Red, Thanks for the response. I have broken upper front shock mounts, a better question is 'are there any replacement mounts out there' or is it find a donor and use that? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | as I said, depends on just what's 'broken', but yes, you'll be looking for a donor or a bolt, there aren't any repros that I know of - some new shocks come with a replacement mounting stud if the riveted on mount plate is OK
Bill | | |
