| The Gallery | ||||||
1958 Chevy 1/2-Ton Utility |
# 2716 More truck pictures in Photobucket! From Robert : This Chevy Task Force utility truck was built for the Tacoma (Washington) Fire Department. It served as a “Fire alarm electrician.” It was assembled in Oakland and the utility body was made at the McCabe-Powers plant in Oakland. The tailgate has a plate that says “Bodies by Powers St. Louis.” St. Louis was the location of the parent company. I had the brake components and a universal floor shift put in, thanks to my trusty and knowledgeable neighbor. It now runs, stops, and shifts. I have removed the doors, the seat and have started the process of filling the holes. I found that most of these trucks have the same rusted out places -- top of lights, behind and in front of the doors. The worst rust is in the doors. The bottom of the passenger door is gone. I am not a perfectionist so I am using the 3M Bondo products: bondo jelly, bondo glass, and bondo body filler. I have also covered a large hole on the driver’s side floor with sheet metal and roofing tar. I am interested in getting this truck on the road by spring and drive it.
