1 members (Patina 54), 75 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
#1052637 08/29/2014 6:55 AM
Trying to start up my 52 but the previous owner pretty much cut off the entire harness. Does anyone have a basic (or detailed)schematic/picture on the wiring for a 216? I was able to turn the motor over (via jumper cables and the floor pedal) but didn't introduce the spark into the equation. I just want to start the motor to see if it will run. Plan is to use a 12 volt battery and a gas can. Currently has a 6V generator. This would be a completely "rigged" setup. Any help or pictures would be awesome. Tried searching the forums but no luck.
J. Sanders
bolter# 38743
Active Duty USAF
Do the following just to get engine running for short period of time...using 12v battery and wont hurt your 6v components:
1. Positive battery cable directly to starter switch.
2. Negative battery cable to frame or directly to engine.
3. Wire from battery positive through 2 pole (on/off) switch to positive side of ignition coil.
4. Wire from negative side of ignition coil to distributor housing terminal.
That's it, it will run. Use the on/off switch to energize coil/distributor. Ensure points are clean and adjusted properly. 12V will not burn out coil or points if only used a short period of time (I think this is true for the coil...might want to pop in 12v coil just to be sure).
Also, might want to gravity feed the carb from gas can sitting on roof of truck...don't let it vibrate off the roof.
Awesome that is just what I needed...stupid question but should I gravity feed the gas via the fuel line or just drip into the top of the carb?
J. Sanders
bolter# 38743
Active Duty USAF
if you have a good fuel pump you don't need to "gravity feed", just set a gas can by the inner fender and run a rubber fuel line into it from the fuel pump, they suck pretty well
If you are sure the fuel pump works, use it. If not gravity feed through the carb fuel inlet. To clarify, on a 52 the "starter switch" is located on/at the starter motor. It is NOT the key switch inside the cab.
Also if you do not know what's inside the stock gas tank then be sure to use an external container with fresh gas.
Best of luck.
1946 1/2-Ton Chevy
Well it fired up!!! Couldn't keep it running though. To many thing are disconnected so a quick start and brief idle/rev was okay for me. Oil sprayed everywhere (pressure gauge was not connected)! Does anyone have a good set of photos that shows items connected fuel, vacuum, oil? I have a new wire harness on the way and will be converting to a 12V. Thanks everyone for the advice
J. Sanders
bolter# 38743
Active Duty USAF
You are welcome to look through my photo album...you just might find what you are looking for.
album
Awesome album thanks David
J. Sanders
bolter# 38743
Active Duty USAF
