2 members (baldeagle, Rusty Rod), 98 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1052398 08/28/2014 2:14 AM
Y
Y Offline
Does anyone know what type of metal the window moldings are made of? 47-54 to be exact. Thanks.
which 'window moldings'? painted or chromed, likely sheet metal, if you suspect SS, check with a magnet
painted or "brightwork"?
Painted moldings were steel.
If they are original bright-work for the front, side, or rear windows it was stainless steel.
Which window?
Which year (there are year-by-year differences)?
Stainless steel can be slightly magnetic, but not as strong as regular steel sheet metal.
Y
Y Offline
I'm asking about the outer window frames or moldings of a 51 suburban. I've seen some with them chromed but mine are not chromed they have paint on them. They are a bit rusted or at least two of them with one being cracked through due to the rust. I was wondering if I would be able to weld them with a mig or tig welder. Sorry I just noticed I didn't specify which windows. I'm talking about the rear sliding side windows.
yes you can weld them .... carefully
The side window "reveals" were never chromed from the factory on any 47-55 Suburban (door windows and rear-side windows).
Pickups and panels had optional "bright" (stainless) door window reveals in 1951.
Y
Y Offline
Thanks guys. I just wanted to know what material they were made of so I know what method of welding to use.
