1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 24 | Does anyone know what type of metal the window moldings are made of? 47-54 to be exact. Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | which 'window moldings'? painted or chromed, likely sheet metal, if you suspect SS, check with a magnet
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | painted or "brightwork"?
Painted moldings were steel.
If they are original bright-work for the front, side, or rear windows it was stainless steel.
Which window? Which year (there are year-by-year differences)? Stainless steel can be slightly magnetic, but not as strong as regular steel sheet metal.
| | | | | Joined: Oct 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 24 | I'm asking about the outer window frames or moldings of a 51 suburban. I've seen some with them chromed but mine are not chromed they have paint on them. They are a bit rusted or at least two of them with one being cracked through due to the rust. I was wondering if I would be able to weld them with a mig or tig welder. Sorry I just noticed I didn't specify which windows. I'm talking about the rear sliding side windows.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes you can weld them .... carefully
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The side window "reveals" were never chromed from the factory on any 47-55 Suburban (door windows and rear-side windows).
Pickups and panels had optional "bright" (stainless) door window reveals in 1951.
| | | | | Joined: Oct 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 24 | Thanks guys. I just wanted to know what material they were made of so I know what method of welding to use. | | |
