| | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 11 New Guy | | New Guy Joined: Aug 2014 Posts: 11 | Trying to start up my 52 but the previous owner pretty much cut off the entire harness. Does anyone have a basic (or detailed)schematic/picture on the wiring for a 216? I was able to turn the motor over (via jumper cables and the floor pedal) but didn't introduce the spark into the equation. I just want to start the motor to see if it will run. Plan is to use a 12 volt battery and a gas can. Currently has a 6V generator. This would be a completely "rigged" setup. Any help or pictures would be awesome. Tried searching the forums but no luck.
J. Sanders bolter# 38743 Active Duty USAF
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Do the following just to get engine running for short period of time...using 12v battery and wont hurt your 6v components:
1. Positive battery cable directly to starter switch. 2. Negative battery cable to frame or directly to engine. 3. Wire from battery positive through 2 pole (on/off) switch to positive side of ignition coil. 4. Wire from negative side of ignition coil to distributor housing terminal.
That's it, it will run. Use the on/off switch to energize coil/distributor. Ensure points are clean and adjusted properly. 12V will not burn out coil or points if only used a short period of time (I think this is true for the coil...might want to pop in 12v coil just to be sure).
Also, might want to gravity feed the carb from gas can sitting on roof of truck...don't let it vibrate off the roof. | | | | | Joined: Aug 2014 Posts: 11 New Guy | | New Guy Joined: Aug 2014 Posts: 11 | Awesome that is just what I needed...stupid question but should I gravity feed the gas via the fuel line or just drip into the top of the carb?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you have a good fuel pump you don't need to "gravity feed", just set a gas can by the inner fender and run a rubber fuel line into it from the fuel pump, they suck pretty well
Bill | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | If you are sure the fuel pump works, use it. If not gravity feed through the carb fuel inlet. To clarify, on a 52 the "starter switch" is located on/at the starter motor. It is NOT the key switch inside the cab. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Also if you do not know what's inside the stock gas tank then be sure to use an external container with fresh gas. Best of luck. | | | | | Joined: Aug 2014 Posts: 11 New Guy | | New Guy Joined: Aug 2014 Posts: 11 | Well it fired up!!! Couldn't keep it running though. To many thing are disconnected so a quick start and brief idle/rev was okay for me. Oil sprayed everywhere (pressure gauge was not connected)! Does anyone have a good set of photos that shows items connected fuel, vacuum, oil? I have a new wire harness on the way and will be converting to a 12V. Thanks everyone for the advice
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | You are welcome to look through my photo album...you just might find what you are looking for. album | | | | | Joined: Aug 2014 Posts: 11 New Guy | | New Guy Joined: Aug 2014 Posts: 11 | Awesome album thanks David
