0 members (),
330
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 256 'Bolter | | 'Bolter Joined: May 2012 Posts: 256 | This past weekend I took some time and CLEANED out my Garage !! Yeah been a while coming, but Man I have more room now, or at least looks that way as all the stuff is somewhat strategically organized. Problem is I found some parts -n- pieces that I need to Identify, and if they are NOT for my 1929 Chevrolet then they need a new home. Item 01... Looks to be an Old Tire Pump of Sorts, has solid woogd handle and a screw on vavleTire Pump 01Tire Pump 02Tire Pump 03Tire Pump 04Tire Pump 05Item 02... Looks to be a bracket or brace of some sorts, was in a box of parts i got with the 1929Bracket 01Bracket 02Bracket 03Bracket 04Item 03... some sort of plumbing or air fittingPlumb Part 01Plumb Part 02Item 04... Looks to be some sort of handle or Tool, approx 3/8" dia, square drive on each endL-Part 01L-Part 02L-Part 03Item 05... Door handles, both have square drive, matching pairDoor Handle 01-01Door Handle 01-02Door Handle 01-03Item 06... set of door handles, 3 total, as pictured, all the handle backs ae split, or busted, made in 2 pieces, shaft is round w/ square end & internal threadsDoor Handle 02-01Door Handle 02-02Door Handle 02-03Door Handle 02-04Item 07... Some sort of jack, has a screw on the shaft, with 3 hole pocket in the top for turning to lift or lower, (L-Part does NOT fit this in any MANNERJack 01Jack 02Jack 03Jack 04Jack 05Item 08... clutch plate, may be an aftermarket plate, disc is approx 10.125" diameter on clutch surface, 3 springClutch Plate 01Clutch Plate 02Clutch Plate 03Clutch Plate 04Cluth Plate 05Please help me identify these parts, and if you need more info PLEASE ask here, also if you are interested in ANY or ALL of these parts -n- pieces PM me, Pretty much pay for the shipping from me to you, and it is YOURS !! that is as long as it does NOT go to my 1929 !! Thanks for the help... 1929 Chevrolet AC International - 4 Door1930 Chevrolet AD Universal - Canopy Express TruckLove the Antique Chevrolet's from 1928-1932 The Beauty, Simplicity, History, and the Stories they Tell[/font] - - In the Stovebolt Gallery-- In the Gallery Forum | | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 | Item 04 is out of an old socket set. My pop had a set w/that tool in it & I would bet if I looked it's most likely still in his shop even though he's been gone almost 10yrs. If I find it I'll take a pic of the set...joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | Item 1 is an old Tire Pump, generally of the kind used for Bicycles.
Item 4 as Large Marge relays, is from a Socket Set.
I have an old socket set myself, which has an "L" Handle like that in it.
Most of the Door Handles shown do look 'Chevrolet' to me...mid to late '20s for the straight ones, latter '20s for the curvey ones, mid '30s for the last pair 'tear drop' sort of shaped ones...but I am less ocnfident the last pair is Chevrolet.
