1 members (Ponchogl), 322 guests, and 3 robots.
Topics128,162
Posts1,057,043
Members48,463
This past weekend I took some time and CLEANED out my Garage !! Yeah been a while coming, but Man I have more room now, or at least looks that way as all the stuff is somewhat strategically organized.
Problem is I found some parts -n- pieces that I need to Identify, and if they are NOT for my 1929 Chevrolet then they need a new home.
Item 01
...Looks to be an Old Tire Pump of Sorts, has solid woogd handle and a screw on vavle
Tire Pump 01
Tire Pump 02
Tire Pump 03
Tire Pump 04
Tire Pump 05
Item 02
...Looks to be a bracket or brace of some sorts, was in a box of parts i got with the 1929
Bracket 01
Bracket 02
Bracket 03
Bracket 04
Item 03
...some sort of plumbing or air fitting
Plumb Part 01
Plumb Part 02
Item 04
...Looks to be some sort of handle or Tool, approx 3/8" dia, square drive on each end
L-Part 01
L-Part 02
L-Part 03
Item 05
...Door handles, both have square drive, matching pair
Door Handle 01-01
Door Handle 01-02
Door Handle 01-03
Item 06
...set of door handles, 3 total, as pictured, all the handle backs ae split, or busted, made in 2 pieces, shaft is round w/ square end & internal threads
Door Handle 02-01
Door Handle 02-02
Door Handle 02-03
Door Handle 02-04
Item 07
...Some sort of jack, has a screw on the shaft, with 3 hole pocket in the top for turning to lift or lower, (L-Part does NOT fit this in any MANNER
Jack 01
Jack 02
Jack 03
Jack 04
Jack 05
Item 08
...clutch plate, may be an aftermarket plate, disc is approx 10.125" diameter on clutch surface, 3 spring
Clutch Plate 01
Clutch Plate 02
Clutch Plate 03
Clutch Plate 04
Cluth Plate 05
Please help me identify these parts, and if you need more info PLEASE ask here, also if you are interested in ANY or ALL of these parts -n- pieces PM me, Pretty much pay for the shipping from me to you, and it is YOURS !! that is as long as it does NOT go to my 1929 !!
Thanks for the help...
1929 Chevrolet AC International - 4 Door
1930 Chevrolet AD Universal - Canopy Express Truck
Love the Antique Chevrolet's from 1928-1932
The Beauty, Simplicity, History, and the Stories they Tell
[/font]
- - In the Stovebolt Gallery
-- In the Gallery Forum
I have more zippers then a pair of cargo pants
Item 04 is out of an old socket set. My pop had a set w/that tool in it & I would bet if I looked it's most likely still in his shop even though he's been gone almost 10yrs. If I find it I'll take a pic of the set...joe
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
A few more to the Mix of What are they...
Item 09
Door Handle 03
Door Handle 03
Door Handle 03
Door Handle 03
Item 10
...Door handles, both have square drive, one has a Key, Feel HOLLOW as they are LIGHT
Door Handle 04
Door Handle 04
Door Handle 04
Door Handle 04
[/font]
Item 1 is an old Tire Pump, generally of the kind used for Bicycles.
Item 4 as Large Marge relays, is from a Socket Set.
I have an old socket set myself, which has an "L" Handle like that in it.
Most of the Door Handles shown do look 'Chevrolet' to me...mid to late '20s for the straight ones, latter '20s for the curvey ones, mid '30s for the last pair 'tear drop' sort of shaped ones...but I am less ocnfident the last pair is Chevrolet.
