4 members (Phak1, Bullriders, Greg_H, 1 invisible), 35 guests, and 0 robots.
Topics128,089
Posts1,056,009
Members48,430
#1051099 08/22/2014 2:25 PM
hello how to remove and replace on a 48 chevy coe door window rubber that stop glass shaking there are two off
thanks tony
fondo #1051123 08/22/2014 4:53 PM
Tony,
Here is the cab manual that should help you see how to replace them.
https://www.flickr.com/photos/advance-design_parts_co/sets/72157641244124604/
Also here is an interior door (47-50) shot of all the bits together.
https://www.flickr.com/photos/advance-design_parts_co/14184302391/in/set-72157631868452754
fondo #1051236 08/23/2014 1:59 AM
The old ones are a bear to get out since they are as hard as a rock. The new ones slide in pretty easy if you can get the channel clean.
fondo #1051290 08/23/2014 6:28 AM
thank you for the info tony
Moderated by  ndkid275, Phak1
