1 members (klhansen),
70
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 11 New Guy | | New Guy Joined: Nov 2013 Posts: 11 | hello how to remove and replace on a 48 chevy coe door window rubber that stop glass shaking there are two off thanks tony | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | The old ones are a bear to get out since they are as hard as a rock. The new ones slide in pretty easy if you can get the channel clean.
| | | | | Joined: Nov 2013 Posts: 11 New Guy | | New Guy Joined: Nov 2013 Posts: 11 | thank you for the info tony | | |
