4 members (cmayna, klhansen, delwrench, TUTS 59), 83 guests, and 4 robots.
Topics128,190
Posts1,057,223
Members48,465
google+
does anyone know where i can find these for a 46 2 ton?
certainly isn't anything that'd be in the repro market, and you're highly unlikely to run across any used, they'd be a DIY item
24601
24601
Andrew -- About the best way to find those is to look for a firetruck, tow truck or some other 2-ton with a body on it using the long running boards and fenders. You will most likely have to buy the whole truck to get them.
Not to say you can't find them if you look hard enough. I'm just saying that I've never seen them except on a few trucks with the bodies I've described.
As Bill says, you're best bet is to try and fab them yourself. Contact Jim Carter (Jim Carter Antique Truck Parts -- look in our links section) -- he has a HD '46 1-ton with those fenders and running boards. He can probably send you some measurements and photos if you end up fabbing your own.
Here are a few pictures of it (Plus a '38)
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thanks for the info guys, That blue Jim Carter truck is exactly what i want my 2 ton to look like.
They were used on Ernest Holmes Wreckers with the "Chariot" style Service body from 1937-1956. Join the Vintage Holmes Wrecker facebook page, & look up Michael Myers. He's found someone that can make them. He's having a set made now.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
24601
24601
Good info, Spanky -- Thanks for sharing!
How's the sleeper cab project coming along? (Not to hijack the thread ...)
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
I found a pair of Polished Stainless Steel rear fenders on Ebay. They are 37" diameter, more or less, depending how much you stretch them, and 21" wide. My tire size is 8.25x20 and this size fender fits them perfectly. They are in the pricey range, about $200 as I remember.
http://www.mrchevynut.com/100_2783.JPG
http://www.mrchevynut.com/100_2784.JPG
Mrchevynut.com
John, isn't Jim Carters 46 a 1 1/2 ton???
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
