| | | Forums66 Topics128,183 Posts1,057,262 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 5 New Guy | | New Guy Joined: Jul 2012 Posts: 5 | google+does anyone know where i can find these for a 46 2 ton? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | certainly isn't anything that'd be in the repro market, and you're highly unlikely to run across any used, they'd be a DIY item
Bill | | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Andrew -- About the best way to find those is to look for a firetruck, tow truck or some other 2-ton with a body on it using the long running boards and fenders. You will most likely have to buy the whole truck to get them. Not to say you can't find them if you look hard enough. I'm just saying that I've never seen them except on a few trucks with the bodies I've described. As Bill says, you're best bet is to try and fab them yourself. Contact Jim Carter (Jim Carter Antique Truck Parts -- look in our links section) -- he has a HD '46 1-ton with those fenders and running boards. He can probably send you some measurements and photos if you end up fabbing your own. Here are a few pictures of it (Plus a '38) John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2012 Posts: 5 New Guy | | New Guy Joined: Jul 2012 Posts: 5 | Thanks for the info guys, That blue Jim Carter truck is exactly what i want my 2 ton to look like. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | They were used on Ernest Holmes Wreckers with the "Chariot" style Service body from 1937-1956. Join the Vintage Holmes Wrecker facebook page, & look up Michael Myers. He's found someone that can make them. He's having a set made now. | | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Good info, Spanky -- Thanks for sharing!
How's the sleeper cab project coming along? (Not to hijack the thread ...)
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2012 Posts: 18 New Guy | | New Guy Joined: Feb 2012 Posts: 18 | I found a pair of Polished Stainless Steel rear fenders on Ebay. They are 37" diameter, more or less, depending how much you stretch them, and 21" wide. My tire size is 8.25x20 and this size fender fits them perfectly. They are in the pricey range, about $200 as I remember. http://www.mrchevynut.com/100_2783.JPGhttp://www.mrchevynut.com/100_2784.JPGMrchevynut.com | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | John, isn't Jim Carters 46 a 1 1/2 ton??? Scott
