| | | Forums66 Topics128,188 Posts1,057,218 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 35 | Any tips or prior threads to remove a seat/base to gain access to fuel tank? We are struggling to get mine out.
Thx! GiG | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | My seat back had 3 screws at the top that held it in to the tube frame. Once that was removed, the seat bottom came out by pulling forward and up on the back end of the seat bottom. 1950 GMC regular deluxe cab. Good luck. Jim | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is a shot of my seat frame, as stated above once the three screws are removed the cushions will pop out. If you want to remove the frame there are four studs with nuts on top that come off the tracks in the corners. You can see them in this shot, you will also need to remove the clamp you can see mid-frame from the cable. A word of caution the corners on the bottom are usually full of spilled coke and junk. Spray them with a good penetrating oil as they will snap off. https://www.flickr.com/photos/advance-design_parts_co/8129072768/in/set-72157631867396207KMAC | | | | | Joined: Aug 2014 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 35 | thank you both! got the seat out... working on fuel tank now.
Brad that's a beautiful truck! | | |
