0 members (), 114 guests, and 1 robot.
Topics128,105
Posts1,056,541
Members48,448
Photobucket Photobucket
My turn signal flasher still works but needs to be rewired. How the heck do I get the old wires out? I don't know if you can tell by the pics, but they are sorta clamped.
Steve, usually the metal fitting is held in similar plugs by a small tab, you press the tab with a small screwdriver or pick and it you can then pull it out.
If all else fails, you can use a headline socket I believe. Pat
1966 Chevy C 30 1 ton truck
that flasher socket can be obtained at any FLAPS, cheap
My local flaps didn't carry any "turn signal flasher pigtails" or whatever the technical term was... the only place that did was O'Reilly's and they wanted close to 15 for one!!!
I bought a 4 dollar headlight socket and the 3-prong flasher unit I have fit right in!
Do you mean head light socket?
53Movinon
head light socket would be the same thing as a headlight (or headline as smiles mistyped) socket I would imagine
