| | | Forums66 Topics128,102 Posts1,056,531 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Photobucket Photobucket My turn signal flasher still works but needs to be rewired. How the heck do I get the old wires out? I don't know if you can tell by the pics, but they are sorta clamped. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Steve, usually the metal fitting is held in similar plugs by a small tab, you press the tab with a small screwdriver or pick and it you can then pull it out. | | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | If all else fails, you can use a headline socket I believe. Pat
1966 Chevy C 30 1 ton truck
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that flasher socket can be obtained at any FLAPS, cheap
Bill | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | My local flaps didn't carry any "turn signal flasher pigtails" or whatever the technical term was... the only place that did was O'Reilly's and they wanted close to 15 for one!!!
I bought a 4 dollar headlight socket and the 3-prong flasher unit I have fit right in! | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Do you mean head light socket? | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | 53Movinon head light socket would be the same thing as a headlight (or headline as smiles mistyped) socket I would imagine | | |
