4 members (Jon G, 5 Window 9434, Charles in CA, dt235sd), 54 guests, and 0 robots.
Topics128,049
Posts1,055,635
#104857 10/16/2003 8:34 PM
I am trying to find out the dimensions for bed wood planks for a 1936 GMC 1/2 ton. The original wood is gone, so I have no pattern to go by.
1936 GMC T-14 1/2-Ton Pickup
#104858 10/16/2003 10:38 PM
Hello dunfire
My 39 GMC has a metal bed so I'm no help. It's good to see the early models showing up. grin
#104859 10/17/2003 1:18 AM
dunfire--if 37 pickups are the same I can help you but there may be different sizes on some early models. Some had 6 boards and on some 7.There was even a length difference on some. I'm sure some one will come along and have exactly what you need!
#104860 10/17/2003 10:01 AM
Mine has six planks and it is the long bed. I just need the width of each plank and the distance that has to be routed on each side for the bed strips to fit flush.
#104861 10/17/2003 10:00 PM
Maybe these will help. The years are a little newer but it will show the grove.
http://50chevy.freeservers.com/Bed_Restoration.html
http://www.chevytrucks.org/tech/bedwood.htm
