4 members (HandyAndy, Jon G, 2 invisible),
148
Mod | | | Forums66 Topics128,087 Posts1,055,982 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 8 Member | | Member Joined: Mar 2002 Posts: 8 | I am taking my truck apart one piece at a time and removing the old paint.This sometimes means that a piece will sit up for an extended period of time after I apply the etch primer. How long can the piece sit before it has to be scuffed and the urethane primer added. Or does it ever need to be scuffed?
2nd question. Do I need to cut the parts in with final color or can I reassimble with primer only. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I can give you my opinion on one of your questions. I'd recommend triming out the parts before assembly. As for the primer, I have lightly used an etching pad over the primer before applying the filling primer. Not sure if all brands of paint are the same or not.  | | | | | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | I would suggest you read the topic Paint technology "basics" that Martin"S" posted here in this forum . It will give you the basics for primers and paints....well worth your while to read and copy and save for future reference. This is something he is well informed in and works with on a daily basis. As always his topics are informative and well worth your time in looking into...give it a try
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I did the same thing with a jeep and I let it sit with no paint on it at all in my dry garage for six months and it didn't rust. I just hit it with a metal wash before I primed it and it stuck really well. If you are storing stuff outdoors or in a wet location prime it right away.
