3 members (DennisM, FAST55, Ponchogl), 143 guests, and 3 robots.
Topics128,268
Posts1,058,376
Members48,485
#104809 04/16/2002 8:56 PM
I am taking my truck apart one piece at a time and removing the old paint.This sometimes means that a piece will sit up for an extended period of time after I apply the etch primer. How long can the piece sit before it has to be scuffed and the urethane primer added. Or does it ever need to be scuffed?
2nd question. Do I need to cut the parts in with final color or can I reassimble with primer only.
#104810 04/17/2002 4:05 AM
I can give you my opinion on one of your questions. I'd recommend triming out the parts before assembly. As for the primer, I have lightly
used an etching pad over the primer before applying the filling primer. Not sure if all brands of paint are the same or not. smile
#104811 04/17/2002 5:57 AM
I would suggest you read the topic
Paint technology "basics" that Martin"S" posted here in this forum . It will give you the basics for primers and paints....well worth your while to read and copy and save for future reference.
This is something he is well informed in and works with on a daily basis. As always his topics are informative and well worth your time in looking into...give it a try wink
37 Chevy 1/2 Ton
86 Chevy Blazer
98 Drudge 24 valve Cummins
One worn out Timberjack
#104812 04/17/2002 10:20 PM
I did the same thing with a jeep and I let it sit with no paint on it at all in my dry garage for six months and it didn't rust. I just hit it with a metal wash before I primed it and it stuck really well. If you are storing stuff outdoors or in a wet location prime it right away.
Paint & Body Shop moderator
