0 members (),
132
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | I want to remove the tranny(420) before pulling eng.can I just remove the shift lever,without removeing the top plate? will removing the roll pin allow me to do this?. thanks again. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Just remove the gear shift lever, disconnect (and move away) the drive-shaft, and remove the gearshift. You do not need that special tool. Push the lever down and twist the lever. It is "spring-loaded" and will then pop-up/out. | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | non of thes sugestions will work.would it be problem to remove the top plate?thank you.. | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | I have no idea as why it wo,nt,maybe I am just short on patience .thank you. | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | I had to spray quite a bit of penetrating spray into the collar to get it to loosen up. Used a set of adjustable pliers to grip it enough to wiggle it free. Just time and patience required. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I had to spray quite a bit of penetrating spray into the collar to get it to loosen up. Used a set of adjustable pliers to grip it enough to wiggle it free. Just time and patience required. Very good advice. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The spring on my shift tower cannot be compressed with finger pressure. The manual shows a tool but I use a monkey wrench, placed on it's side. That allows me to deliver enough force to compress the spring. Then, it turns about 15 degrees counter clockwise and it pops up. | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | 2 good sized straight screwdriver or prybars, insert into retainer 180 deg apart. Press straight down until the retiner tangs clear the pins & apply pressure to rotate counter-clockwise. Retainer should come up & out. Taking the shift cover off will open up another can of worms!
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | |
