4 members (Woogeroo, klhansen, jay d, 1 invisible),
130
Mod | | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | Im running a 235 out of a 62 Impala in my 49 pickup. Starts great every time Idles fine when cold but as temp starts to rise my idle speed starts to slow down, while driving if I come to a stop sign or red light it will completely die, I hit the starter button an it starts just fine but as soon as I take my foot off the gas it dies. I am running the stock Rochester one barrel. Do I need to get a carb kit an see if that helps or do I need to start looking for a new carb, if so any recommendations for a new carb? Thanks for any advice you guys can give me. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Is it an old problem or a recent engine swap?
| | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | It is a recent engine swap, Carb came with engine | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Definitely rebuild and if it still persist then swap carbs. Rebuilds are cheap and easy. How close is the fuel line to a heat source? Maybe it's boiling off at idle?
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Before you go too deep try properly adjusting the carb w/the engine warmed up to operating temp.
If you have a vacuum gauge, connect it to the manifold vacuum port and adjust the fuel/air mixture and idle speed to get the highest steadiest reading at idle.
IF the above doesn't correct it test for a vacuum leak at the carb, where it bolts to the manifold and where the manifold bolts to the head. Assuming you have an automatic choke, your symptoms sound like a vacuum leak, i.e. as the choke opens the fuel/air mixture leans out and a vacuum leak will make the idle mixture too lean to idle. Course when you don't know the history of a carb a rebuild is a wise move. Good luck Dave | | |
