| | | Forums66 Topics128,204 Posts1,057,292 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Obviously this is personal preference, but working on the door of the 48 2 ton made me wonder.
The doors are straight and rust free. A little sun burn and some surface scratches.
Getting them ready for paint I noticed some shallow creases near the front edge of the edge of the door. They were made when the door skin was originally installed. You couldn't see them in the oxidized pain, but when sanding you can feel them. With hi gloss paint, standing in the right spot, you could notice them.
Also noticed some of the spot welds on the inside door panel and around the door frame were made too deep razing a sharp ring around them.
Do you start skim coating an otherwise good door to remove factory tooling marks? Or, it was good enough for the factory......
Opinions? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | That's completely your decision, I think. Some restored trucks look "too smooth" to me, but if the owner likes it that way who am I to say it's wrong? | | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | Are you building for selling, or enjoying? I've pondered the paint and body question numerous times. And I'm by no means a pro at either. Right now, my 52 sits in flat black primer. Love the stuff! While I'm working on it, I don't ever worry about scratching anything up. Even if I do, hit it with the primer again. I have hopes of maybe a satin finish one day, but glossy will make me think twice about driving and enjoying it. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | It's all about you Jim. I think the answer lies in what your plans are. If you are going to leave the truck nearly all stock leaving the body in its OEM state would be logical. If you are updating drive train, braking, etc. and want the truck to also reflect an upgraded body, then have at it. At least that's my 2 cents. IMHO it's all good. John | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I agree with these guys thoughts. Mine has 3 different colors including 2 shades of green and enough rattle can spray paint to make it an ozone hazard. But, it's my truck.
Drew
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do what you like.
I leave mine Au Naturel (spot welds and tool marks) - as they looked when GM sent them out the factory.
| | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | I know how you feel. I am contemplating going to the trouble of heating and dimpling the replacement outer cowl to create fake spotwelds at the hinge pillar. Or just leave them smooth. Carl
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Jim,
If factory production is what you are looking to achieve, then I would suggest you leave the tooling marks. It is easy to begin over-restoring if you are not careful. I think the die marks and spot welds add to the character and story of the vehicle.
Paul | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My take on things: If you are going for 100 point show quality restoration, you need to leave things as the factory did them originally. However, any other purpose and do what you personally like. For me, I did a combination of both approaches. For instances on the tailgate: I left the spots welds visible from the outside, but got rid of them on the inside. I filled the spot welds on the top of the bedsides (at stake pockets). Same for inside skin of doors (where spacer was spot welded to interior door skin) and generally smoothed the door jambs. I also deleted the rivets at the rear fender braces.
It all personal preference, but I knew I was not going for a 100 point perfect restoration as I did my own painting and the simple fact is that I am good, but not that good. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Thanks for the comments, just wanted to see what some of you were thinking.
It's modified so it isn't going to a show as an antique, probably won't ever be at a local car club show either.
I will grind down some of the spot welds, some are actually bad enough to cut your self on, and fill the ones on the inside door panel. Going to a little higher level on the interior because of the custom leather.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The thing I am seeing (and maybe I am all wrong) is that as the generations progress, times change, the kids are now the parents, and they fantasize about these trucks more because they weren't actually there. What would a fantasy version of this vintage look like? Spot welds? Hello? So... not that I agree with it, but I feel that even at the most coveted show on earth, the cleanest, well done job will win. This would be a mismatch of factory vs what they expect from TODAYs factory.
I am hearing that at Pebble Beach, the judges are considering taking points off for using high tech Urethane. Your head would spin if you were trying to please everyone. Part of the coolness of all this is the PERSONAL presentation. What you do, without the opinions of others, makes your truck really yours. Be a man, stand up, do what your heart tells you to do, and accept the reward, consequences, whatever. If those spotwelds bug you. Fixem! | | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Around here, local show "judges' (loosely termed) show a bias against strictly restored to as-built condition. It is not intentional. It stems from their lack of knowledge of the vehicles which they are judging. If some of them do recognize a restored as-built vehicle, they have no idea about the extra effort it takes to create one compared to building a modified vehicle, and favor the snazzy custom. Meanwhile the crowds of people coming to the show, spend more time ogling the old as-built vehicles and ask a million questions about them.
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I do antique mechanical restorations, mostly tractors and farm equipment, so the truck is an anomaly. Yes, it was a farm truck and it is going to be used to carry tractors, buy it is modified and customized.
Anyway, I do find a lot of clients have an idealized vision of Grandpa's tractor. They want all original parts, accessories and equipment, but then want the "fit and finish" of a Lexus. Those get all the ooh's and ahhh's at the local fair. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Anyway, I do find a lot of clients have an idealized vision of Grandpa's tractor. They want all original parts, accessories and equipment, but then want the "fit and finish" of a Lexus. Those get all the ooh's and ahhh's at the local fair. Jim, that is a pretty doggone good way to put it. Mmmmm, maybe there is a tat bit of me in that phrase too. | | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | We're only caretakers for the short time that we are on earth, please yourself.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | My two cents. When I started on my truck I refinished it to the best of MY ability. Not a lineman working to bust rump to keep up with the demands from the factory 60 years ago. I imagine those workers and for that matter I know I appreciate the extra hours to make the fit and finish of truck look as nice as I am able. "period correct" or not. | | | | | Joined: Oct 2009 Posts: 42 New Guy | | New Guy Joined: Oct 2009 Posts: 42 | A truck, or for that matter any classic vehicle is ultimately a reflection of it's owner's personality in purest form. Whether you like it or not. We all want and try to do the right thing and there's usually a gut feeling that it's either right or wrong despite what others say or advise, a kind of balancing act which never ends. Patience. Probably best tool in the draw. Deep huh. Someone get me sweet coffee. | | |
