| | | Forums66 Topics128,158 Posts1,057,025 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 38 | I have the old style steering arms with the worn out ball on my 48 1/2 t truck. Anybody got ideas on how to "press out" the ball in order to use the newer style Tie Rod Ends with the stud and nut. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The secret is at the bottom of the tech tip where it talks about the countersunk hole. If you cut a relief in that area it will come out a lot easier. | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | There's a couple of pics of the job in my photobucket link at the bottom of this post. Mine came apart with no problems, a little kroil and big hammer and punch, and they were out. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....also pics in my photobucket of me doing it on my 52 so you should be covered  | | | | | Joined: Nov 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 38 | Thanks guys for the info and the link to the "Tech Tips". Problem solved. Drilled each of the balls out with a 1/4" drill, then upsized each hole to 7/16". The rollover/flare on the back side was ground off then a large punch and hammer was used to drive the balls off, leaving a nice 1/2" dia hole for the new tie rod ends.
The Drag link balls left a larger dia hole -havent measured them yet. Now I will have to either order a new Drag link or if i get real lucky find one at a Swap Meet. Will have to go with the '54 and later style Drag Link. Anybody out there got one. | | |
