2 members (kades51, TUTS 59), 234 guests, and 2 robots.
Topics128,095
Posts1,056,067
Members48,433
Hey All
The passenger side door on my 46 2 ton keeps opening up while driving.
It closes fine while stopped, I cant pull it open.
Can somebody tell me what i can adjust to keep this from happening? My huntin dog wont sit next to the door anymore it happens so frequently.
Are the cab mounts/supports in good condition, or is the cab flexing while moving? Is the latch striker adjusted?
Lots more pictures
cab mounts are about 2 years old. I dont think they are loose but will check today.
Are your hinge-pins tight, or are they loose enough to let the door move up-and-down?
the striker plate looks worn, I just ordered a new one from jim carter truck parts, we will see if this fixes the issue.
Jay,
The latch should catch on the second part of the catch as looking inward towards the cab.
The reproduced catches don't look like they were made anywhere near North America, you will need to machine the mating side towards the cab pillar so it is flat. The ones I used were convex and would not stay screwed in place.
Good luck, as dogs like trucks just as much a guys.
Paul
Lots more pictures
My lower hinge pin was the culprit. I replaced the pin,the body lines finally are straight,and the door shuts nice and tight.
Mo' Tater
im going to clean off the grease, mark the striker plate with a sharpie pen and then open and shut the door a bunch of times. That may give me an idea of whether the problem is a door thats not aligned, or just a worn out striker.
Open the door a few inched and pick up the back end to check worn hinges like Willy suggested. You should be able to rock the whole cab, not just move the door up and down. Worn hinges allow the door to bounce/flex off the striker plate and come open.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
My 51 does that, but it needs a new latch. I keep hoping GM will have a recall, or maybe Ford would cover it on the Escape recall for doors coming open
Originally Posted by tinnerjohn
My 51 does that, but it needs a new latch. I keep hoping GM will have a recall...
yahoo Now that there's funny!
I've had passengers in my truck where I wished their door would have opened, while I was making a left hand turn. not me
Hey Paul
you were not kidding.
I received my striker plate today in the mail.
the quality is really really terrible.
I think the original part number is 598777
Im trying to remember the places which have NOS parts, perhaps if I give them the part number they can check.
i found partsvoice.com
problem solved.
Jay,
If you have some time and patience, you can file the striker plate flat on the mating surface and it will work. It seems that the Chinese reproduction plant just lost interest in the machining before they were done.
Of course NOS would be better.
You want to make the door right for your dog buddy, but for some other less desirables perhaps it is a great feature. The mental image of (insert the nemesis of your choice) tumbling out over the running board on a hard left turn is kind of funny.
Paul
Lots more pictures
Make sure you have insurance!!
Mo' Tater
Or don't forget to collect and dispose of the "evidence". Abandoned vertical mine shafts are plentiful out there. A "hiker" not paying attention could fall into one very easily..... wink
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
