7 members (Phak1, diseasel, Shade Baby, 46 Texaco, Biermann, Woodcmiami, 1 invisible),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,835 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I washed my engine block today and after letting the truck dry for 5 hours in the texas sun, I went to turn it over and the starter is not turning.
I think its obvious I shorted it out. What do I do at this point? | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Is the starter turning at all? | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | | | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Have you checked to see if the battery is charged? If it is fully charged I would check to make sure you have a good/clean/tight ground connection (battery to frame). Then I would check the positive connection to the starter. Still nothing I would pull the solenoid off and check and clean it. Thats where I would start. | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | The water may have made a corroded cable connection worse. Clean the connections and test. If that doesn't work, I would pull the starter and roll it around to see if water runs out of it. I would then attach power to it on the bench and see if it works.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Considering that this truck is my daily driver, yes the battery was fully charged as of yesterday evening. The interior electronics are functioning.
I replaced the entire electrical system back in January, the cables are all brand new.
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Just went and checked it again, when I push the button on the Solenoid I can hear it sparking inside the starter but it does not turn, just sparks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | time to open it up and clean it out, water turned all the brush dust to sludge
Bill | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I swapped out the starter this morning. Good to go now. | | |
