3 members (Stewart2, 55shaker, 1 invisible), 145 guests, and 3 robots.
Topics128,165
Posts1,057,010
Members48,458
I washed my engine block today and after letting the truck dry for 5 hours in the texas sun, I went to turn it over and the starter is not turning.
I think its obvious I shorted it out. What do I do at this point?
DJ __|__
--O-(_)-O--
'54 Chevy 3100
http://imgur.com/5XR6yO3
8
8 Offline
Is the starter turning at all?
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
Nothing at all
DJ __|__
--O-(_)-O--
'54 Chevy 3100
8
8 Offline
Have you checked to see if the battery is charged? If it is fully charged I would check to make sure you have a good/clean/tight ground connection (battery to frame). Then I would check the positive connection to the starter. Still nothing I would pull the solenoid off and check and clean it.
Thats where I would start.
Curt Warren
Salt Lake City
The water may have made a corroded cable connection worse. Clean the connections and test. If that doesn't work, I would pull the starter and roll it around to see if water runs out of it. I would then attach power to it on the bench and see if it works.
Considering that this truck is my daily driver, yes the battery was fully charged as of yesterday evening. The interior electronics are functioning.
I replaced the entire electrical system back in January, the cables are all brand new.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
Just went and checked it again, when I push the button on the Solenoid I can hear it sparking inside the starter but it does not turn, just sparks.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
time to open it up and clean it out, water turned all the brush dust to sludge
I swapped out the starter this morning. Good to go now.
DJ __|__
--O-(_)-O--
'54 Chevy 3100
