1 members (baldeagle),
43
0
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | Hey All I want to create a custom shift pattern plate out of aluminum to mount on the dash of my 1946 2 ton chevy. Since this is essentially a one off, I didnt know who could custom print on aluminum sheet. something similar to this http://forum.ih8mud.com/threads/custom-gear-shift-instructions-plate.569354/any help would be most appreciated | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | find a custom screen printer, or an engraving shop, like one that does trophies
Bill | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | hey red58 great idea. I was going to make the layout on my computer then I can take it to a trophy place as you suggest. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've used brass plates and printed circuit etching methods to do similar projects. https://lh4.googleusercontent.com/-...9MHqyo/s1280/2012-12-25_13-38-12_809.jpghttps://lh3.googleusercontent.com/-...FbT0Os/s1280/2012-11-16_17-06-00_817.jpgIn this case you mask everything you want to be high, likely the letters and pattern and a border. Then everything else is etched away several thousandths of an inch. You can then either polish the high spots and leave the background as is or paint the whole thing and ever so gently sand the paint off the high spots. I have an aluminum Roadranger shift tag that is of a very nice style but not quite correct for my model transmission. I will eventually make the necessary changes and make a new one on a brass sheet. Grigg | | |
