4 members (Otto Skorzeny, Gray_Ghost, BarryP, Jeff Ogden), 117 guests, and 1 robot.
Topics128,147
Posts1,056,805
Members48,454
Any idea if anything in front of the radiator has to be removed to swap a cam in a 60-66 pickup with V8? Do the radiator support cross pieces get in the way?
Its been a long time since my brother and I did one but I don't think they are a problem. Get the other stuff out of the way and I think it'll come out... I THINK. (and that's dangerous)
If they do, I can maybe tilt the engine a bit by loosening a mount. I just hope to avoid the cross pieces since they are riveted in.
Could just yank the motor?
That would probably make it too easy! smile
Measure with a tape measure from the timing chain cover to the radiator support,If that measurement is longer than the engine , the cam will come out without a problem.
Tommy
59 apache 1/2t
261 short stepside
Without disassembling the front of the engine, it's too close to call. Oh well, I'll find out!
replaced the cam on my 66 c10 two years ago and i don't remember
drilling out any crossbraces so i think you are good to go
Words of encouragement! Luv it! Thanks guys.
just remove your rad lots of room to do job
Woods, you ever get that cam in?
The truck is in for body work and paint. I won't get it back for at least another month. Then my fun begins again. I have to install the bed wood (I have it milled and sealed), the cam, new heads, serpentine drive, underhood Vintage Air components, and the interior insulation and mats. Then it's done.
Awesome! Sounds like a sweet project. Good luck and take care.
James
Thanks James,
It's a SoCal truck that has been in the family since about '69. We had it shipped here about 10 months ago. Been working on it since.
