6 members (Jay R, Otto Skorzeny, Bill Hanlon, rick46ia, TUTS 59, 1 invisible), 53 guests, and 3 robots.
Topics128,023
Posts1,055,366
Members48,420
Can you weld through Zero Rust? I got my frame blasted today and I will be welding the holes shut, reinforcing the rear part of the frame and boxing the entire frame. On the inside of the frame, before I box it shut, what should I use? Can ZeroRust take the heat of welding and still keep away rust? I plan to rustproof the inside of the frame but I still want something covering the bare metal first. Any and all suggestions welcome.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Anonymous
Unregistered
Anonymous
Unregistered
I would not recommend welding through ZR as it will contaminate the weld as would any other paint, rust or grease. I have had to do some fab rework on my frame after I painted it with ZR but I use a wire wheel to clean the area first, do the rework, remove the weld splatter/flux, and then repaint the area using ZR from a rattle can. The ability to retouch areas when using ZR is one of the benefits in my opinion. I like the stuff.
Scott,
It may or may not be practical, but I have used the "pour in roll around" drill on irregular interiors (like doors) to get everything coated. I then drain out the excess ZR into the can for use elsewhere. Get a short case, call some friends and invite them over for a "frame tossing party", tape up all the holes, pour in a quantity of ZR and roll the frame over and around until everything is coated, let it drain and attack the short case.
Bruce Palmer
[email protected]
Is boxing in a frame a common thing? Isnt the frame desinged to flex so it will flex back into position?
blast the frme. apply a metal conditioner ($25.00 a gallon)that will prevent rust. make your repairs and apply ZR.
Get busy liv'n or get busy die'n
Quote
You can also use the ZeroRust "PrepStep". That stuff is amazing.
