7 members (cmayna, Otto Skorzeny, oldsteve, Hanks custodian, Stovebolt48, gswbbc, Maybellene),
143
Mod | | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Can you weld through Zero Rust? I got my frame blasted today and I will be welding the holes shut, reinforcing the rear part of the frame and boxing the entire frame. On the inside of the frame, before I box it shut, what should I use? Can ZeroRust take the heat of welding and still keep away rust? I plan to rustproof the inside of the frame but I still want something covering the bare metal first. Any and all suggestions welcome. Scott | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I would not recommend welding through ZR as it will contaminate the weld as would any other paint, rust or grease. I have had to do some fab rework on my frame after I painted it with ZR but I use a wire wheel to clean the area first, do the rework, remove the weld splatter/flux, and then repaint the area using ZR from a rattle can. The ability to retouch areas when using ZR is one of the benefits in my opinion. I like the stuff. | | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Scott, It may or may not be practical, but I have used the "pour in roll around" drill on irregular interiors (like doors) to get everything coated. I then drain out the excess ZR into the can for use elsewhere. Get a short case, call some friends and invite them over for a "frame tossing party", tape up all the holes, pour in a quantity of ZR and roll the frame over and around until everything is coated, let it drain and attack the short case. Bruce Palmer [email protected] | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Is boxing in a frame a common thing? Isnt the frame desinged to flex so it will flex back into position? | | | | | Joined: Mar 2004 Posts: 48 New Guy | | New Guy Joined: Mar 2004 Posts: 48 | blast the frme. apply a metal conditioner ($25.00 a gallon)that will prevent rust. make your repairs and apply ZR.
Get busy liv'n or get busy die'n
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | apply a metal conditioner ($25.00 a gallon)that will prevent rust You can also use the ZeroRust "PrepStep". That stuff is amazing. | | |
