| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 6 Member | | Member Joined: Jan 2004 Posts: 6 | Trying to find out what color the steering wheel is on a 41 1/2 ton pick-up, and where can I get some? Thanks | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Since no one answered I will. Though I'm not much help. The original steering wheel is supposed to be a certain brown. If you go to a paint shop they'll mix any color you want (if you have some kind of sample color). Make sure you tell them what your painting so they can mix the proper paint. They might recomend a certian paint for plastic. Good luck. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Try the Eastwood Company. They make all kinds of restoration products. Scott | | | | | Joined: Jan 2004 Posts: 6 Member | | Member Joined: Jan 2004 Posts: 6 | Thanks for the responses. I'll try a local paint shop. I've got a decent wheel they might be able to match. Tony | | |
