1 members (klhansen), 160 guests, and 2 robots.
Topics128,132
Posts1,056,729
Members48,454
What is the proper way to lift a straight six out of one of these old trucks. I took off the rocker arm and bolted a chain on opposite corners. But I can't help but think that Chevrolet in Detroit did it differently.
Glory Bound...
What year truck?
Usually there is an illustration in the Shop Manual.
Is the hood off the truck?
Is the transmission disconnected from the engine?
Most likely lift-bolts on opposite corners of the head will work fine.
'57 2 ton with a 261. Yeah I usually take off the hood when pulling an engine. True, lift bolts on opposite corners of the head work. But we're back to taking off the rocker arm. Or is there some trick or tool to avoid taking off the rocker arm?
Glory Bound...
I have lifted 235 and 261 engine by the rocker-arm bolts.
Or, use eye-bolts for the lift, as shown in Shop Manuals.
I have used the engine mount boss ion the side of the engine, this is pretty close to balance neutral. Of course if your engine doesn't have the side mounts ,it's back to the two bolts in the head.
Tommy
59 apache 1/2t
261 short stepside
When I took mine out... I ran a chain in an 'X' pattern, two bolts at the back of the bellhousing (tranny was already removed), and then there were two side bolts about 1/2 to 3/4 of the way to the front of the engine (one was just past the distributer, and the other on the other side in the same location). Worked just fine for me!
Here is how I lift the engine and transmission together using a forged eye bolt and clevis at a single lift point. If you are just removing the engine without the transmission, you would need to use a head bolt further towards the front.
[img]http://www.surfacezero.com/g503/data/3764/2013-07-14_12_24_31.jpg[/img]
Lots more pictures
Thanks for the responses guys. I especially like the method Paul used. Thanks again.
Glory Bound...
Just another reason why I want a front end loader to play with. grin
Drew
