| | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 15 New Guy | | New Guy Joined: Oct 2011 Posts: 15 | when I park the truck (52 Chev 1/2 ton PU)on any angle to the side, even a slight grade, gas leaks out of the gas cap. I believe it generally occurs when the tank is full. Any way to stop the leak or is it just the nature of the truck? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Gas expands as it gets warmer. In warm weather, gas in the ground storage tank is usually cooler than in the truck tank. A full tank of gas could easily expand enough to result in overflow.
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Stop filling the tank as soon as the pump clicks off the first time. leaves room for expansion. | | |
