6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
#1041277 07/09/2014 10:34 PM
Can the 48-51 cabs be interchanged with the 52-53 cabs? Or are they different around the door latch areas?
Use the latches/catches for the year of the doors in whatever 48-53 cab you use.
Gas Pumper
Gas Pumper
Tim is right as usual, but the problem then is if you are a picky person like me, you have two very large holes that are exposed and it really doesn't look right on the cab striker plate area. I have tried to find decent striker plates for the cabs that cover those holes like the earlier year striker plates. So far the only way I can see to do it, is to use a 47-50 striker plate and modify it to have the profile of the 51-55 plates. I have some on the welding bench right now that I will change the profile by adding weld and cleaning the old ones up since there really isn't a decent way to resolve this.
Whats worse is, once you have added the weld and shaped the striker plate to perform exactly as the newer style, what do you do to make it look decent? Re-Plate? Paint, Powdercoat? If you are the best welder under the sun you MIGHT make the weld look nice enough to replate. Maybe. Painting will wear off, so will powdercoating. Im at this stage right now with mine. All geniuses welcome!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
I was thinking the cab where the striker plates mount was a little different shape in the sheet metal?? Wouldn't '51 have the old style striker plates also? That was the last year for the pull down handles.
Rear cab mounts on 48 mid 49 are not the same as later cabs.
The Master Parts Catalog shows 47-51 and 52-54.
16.335: Striker - Spacer - Shim
Gas Pumper
Gas Pumper
yeah, true. same problem tho. Those with 52 and up doors on the older cabs need the wraparound style striker to make it look decent, or... weld the holes shut after you put in the plate, which I wouldn't do. I even called a company called Triquemfg.com and tried to see if they had a solution. Not for original door hardware. In a perfect world, you would be able to get stainless steel striker plates in that configuration.
Deve
The Think Tank
So if I wanted a replacement cab, sounds like I'm limited to 1952 and 53 years..... makes for a small world....
