0 members (),
163
0
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Can the 48-51 cabs be interchanged with the 52-53 cabs? Or are they different around the door latch areas?
John | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Use the latches/catches for the year of the doors in whatever 48-53 cab you use.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Tim is right as usual, but the problem then is if you are a picky person like me, you have two very large holes that are exposed and it really doesn't look right on the cab striker plate area. I have tried to find decent striker plates for the cabs that cover those holes like the earlier year striker plates. So far the only way I can see to do it, is to use a 47-50 striker plate and modify it to have the profile of the 51-55 plates. I have some on the welding bench right now that I will change the profile by adding weld and cleaning the old ones up since there really isn't a decent way to resolve this.
Whats worse is, once you have added the weld and shaped the striker plate to perform exactly as the newer style, what do you do to make it look decent? Re-Plate? Paint, Powdercoat? If you are the best welder under the sun you MIGHT make the weld look nice enough to replate. Maybe. Painting will wear off, so will powdercoating. Im at this stage right now with mine. All geniuses welcome! | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I was thinking the cab where the striker plates mount was a little different shape in the sheet metal?? Wouldn't '51 have the old style striker plates also? That was the last year for the pull down handles.
John | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Rear cab mounts on 48 mid 49 are not the same as later cabs.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The Master Parts Catalog shows 47-51 and 52-54. 16.335: Striker - Spacer - Shim | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | yeah, true. same problem tho. Those with 52 and up doors on the older cabs need the wraparound style striker to make it look decent, or... weld the holes shut after you put in the plate, which I wouldn't do. I even called a company called Triquemfg.com and tried to see if they had a solution. Not for original door hardware. In a perfect world, you would be able to get stainless steel striker plates in that configuration. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | So if I wanted a replacement cab, sounds like I'm limited to 1952 and 53 years..... makes for a small world....
John | | |
