0 members (),
389
8
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 24 New Guy | | New Guy Joined: Mar 2014 Posts: 24 | Only took me 3 months to do a weekends worth of work- but I finally got the ole 235 in the truck woke back up and running! Cause it didn't happen w/o a video ;-) new battery, new fuel pump, rebuilt the extra R1 carb that came with the truck (thanks to George for the fast idle arm!). Fired right up and idled after some cranking to get gas through the lines & carb. Good Oil pressure. Some valve noise- but overall I'm stoked! Currently running off a plastic gas can bungee corded to the hood hinge- The gas tank has been de-gunked, cleaned out, painted & re-installed- Just need to bend up some new hard lines this weekend and I'll be ready to move onto the brake system! (hole rusted in a brake line is what caused the truck to be parked in '92- so it needs all new hard and soft lines. Hoping I won't have to replace the master and wheel cylinders... Anyway, some more pics: Cleaned out, wire wheeled & primed original gas tank After wire wheeling & priming tank floorpad Gas tank re-installed | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | It's so cool to bring one back to life. Good job.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Good job on getting it running. If it was mine I would pull the valve cover off for a look. Almost sounds to me like you have a bent pushrod. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Don't scrimp on the brakes. Replace everything except the drums, if they are turnable. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | simply fantastic and thanks for the pictures....and the little one is cute! | | |
