8 members (Perro, Hush, Lightholder's Dad, John L., Otto Skorzeny, lumbersawyer, FAST55, Hanks custodian),
182
Mod | | | Forums66 Topics128,075 Posts1,056,007 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Hello, Im from England and have recently had a 1949 chevy 3100 imported. Not sure if many on here are from england or not, but the trucks are gaining popularity here. I want to keep it looking standard (maybe a touch lower). A 350 sbc will be going in soon (not sure on everyones views on that yet) along with much needed new wiring, brakes etc.. Anyway hope to learn a lot from you.
| | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Lowering it 4 inches (front and back) makes it look much better. The tires come right up to the bottom lip on the fenders. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Welcome to the Stovebolt jonnyenglish. Yes, there are others here from the UK so visit often and watch where they are from. You find them.....or they'll find you.
What you are planning to do to your truck has been done many times and folks here are willing to help. For the best results just be sure to post questions in the most appropriate forum. Like engine questions in the engine forum, driveline questions in driveline forum. Don't forget to check out the gallery, tech tips and links sections. There is tons of info there as well.
Good luck and post us up a picture or two when you can. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome jonny, yes you're not the only Brit on here, certainly room for you in any case. You came to the right place if you want to learn. It has certainly helped me. Good luck with the truck.
Leo | | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Thanks for the kind welcome.
When I get 5 minutes il try to figure out how to post a couple of photos. Yeh, im not trying anything too new to what im doing to the truck so hopefully I wont come across things that cant be answered on here.
Thanks again | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Johnny,I'm not quite from England but just up the road in Scotland. Hey,at least we're on the same island!
These trucks,both Chevy and GMC are in their hundreds now in the UK.
You'll find all the info you need right here,not to mention a fine bunch of folks... 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Hello Jock, I like your plans for yours. Yep, it seeems they are a fine bunch here... Let the questons begin...!
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | One more reply/post and you can send PM's an enjoy everything there is being a stovebolter! indeed, let the questions begin! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jonny,mine's had a slight change of direction from the gallery story,that was quite a while and many £££s ago!  I see yours already has a V8 do you have any plans other than lowering it? (There's loads of different ways of doing that.) I assume it may already have a different rear axle too on account of the V8,your truck should have had a torque tube originally which don't usually work in that situation. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Haha, the V8 is sitting by the side of the truck on the floor, as is the rear axle!, they are waitng for me to get my finger out!! Ive got a 8.5" 10bolt lsd, will need to get a prop made. I've just posted a question about lowering advice - unfortuantely im on a low budget at the moment so no front clip for the time being so looking at lowered springs front and rear. Is there any newer info on yours, Jock. Cheers | | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Not much more info,i've been slacking on keeping my Flickr page up to date. I know what you mean about 'limited budget' though. Due to some bad advice and workmanship (not from here I might add!) i've basically had to re-do my front and rear suspension which hurt my budget somewhat. I've still got bodywork to attend to if I could stop driving it!
The main 'issue' you will find with fitting the V8 and stock steering is probably header/exhaust to steering clearance. I'm running a MII IFS so that doesn't really relate to yours,the guys in the Hi-Po section will keep you right though. (Use the search function and i'm sure you'll find the info you need) The 10 bolt rear's a good choice though,nice width and better ratio,I assume you'll be changing the front to discs (worthwhile) or else you'll have to run 2 different wheel bolt patterns. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2014 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2014 Posts: 34 | Jock, thats bad luck (and very annoying) with the bad work youve had done. Yes i've also got a disc kit for the front to match the 5 on 4.75 bolt pattern along with better brakes.
Yeh ive found a little info on the steering box being in the way - until i can find more money and upgrade that, it will have to be spaced away from the headers and steering arms bent little i guess. Im having to make sure im using the correct words here!! headers = manifolds in uk, fenders = wings, rockers = sills.......I may get in wrong from time to time, feel free to pick me up on that! | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Keeping the PCD the same front and rear the same,especially 5 bolt Chevy opens up a huge choice of wheels styles.
Glad to see you've got your priorities in order too in getting it stopping first,no point in sticking a V8 in if ya can't stop!
