6 members (fonz8261, Barry Martak, 55shaker, TUTS 59, LAJones48, Dusty53), 142 guests, and 2 robots.
Topics128,088
Posts1,056,416
Members48,443
#1040442 07/06/2014 11:29 PM
I
I Offline
Does anyone know where a set of 15 x 4 rear shoes for a 65 C60 can be found? I found a Raybestos and a Centric part number, 108PG and 11201080 respectively. I have searched high and low and cannot find anyone who carries these. Raybestos 427PG looks similar but does not have the required return spring hooks built onto them. I will probably end up having to get them relined but I want to try and find a set first. Anyone have any suggestions out there? I am also in need of the return springs too.
1965 Chevrolet C-60 292 Flatbed
2008 GMC Sierra SLE Z71 Crew Cab
1992 Chevrolet C1500 Cheyenne 5 Speed
2001 Harley Davidson FLHT Electra Glide Standard
3B Offline
Hy IHBoilermaker, you're right they are proving hard to find, the part numbers don't want to cross at Napa or RockAuto. According to my Raybestos master reference guide that truck used Bendix manually adjusted rear brakes. The return spring kit I found is Raybestos p/n H9223 $15.41 at RockAuto. This return spring kit uses four barrel shaped springs per wheel, does that sound correct for your truck? I'll keep looking, but everything I've tried so far has proved fruitless.
Hi Boilermaker, have you considered having your originals relined?
That's what I ended up doing.
At least you will know you have the correct shoes when you're done.
3B #1041097 07/09/2014 2:47 AM
I
I Offline
The springs look correct. Yes it has the 4 barrel shaped springs that like like those. I'm going to go ahead and order the kit. Looks like a reline will be in the future for my shoes.
thank you 3B for the info about the rear brake shoe spring I've been searching hi-lo couldnot find them anywere
Raybestos p/n H9223
broken rear spring 50 C-60
