| | | Forums66 Topics128,131 Posts1,056,373 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | Does anyone know where a set of 15 x 4 rear shoes for a 65 C60 can be found? I found a Raybestos and a Centric part number, 108PG and 11201080 respectively. I have searched high and low and cannot find anyone who carries these. Raybestos 427PG looks similar but does not have the required return spring hooks built onto them. I will probably end up having to get them relined but I want to try and find a set first. Anyone have any suggestions out there? I am also in need of the return springs too.
1965 Chevrolet C-60 292 Flatbed 2008 GMC Sierra SLE Z71 Crew Cab 1992 Chevrolet C1500 Cheyenne 5 Speed 2001 Harley Davidson FLHT Electra Glide Standard
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy IHBoilermaker, you're right they are proving hard to find, the part numbers don't want to cross at Napa or RockAuto. According to my Raybestos master reference guide that truck used Bendix manually adjusted rear brakes. The return spring kit I found is Raybestos p/n H9223 $15.41 at RockAuto. This return spring kit uses four barrel shaped springs per wheel, does that sound correct for your truck? I'll keep looking, but everything I've tried so far has proved fruitless. | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Hi Boilermaker, have you considered having your originals relined? That's what I ended up doing. At least you will know you have the correct shoes when you're done. | | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | The springs look correct. Yes it has the 4 barrel shaped springs that like like those. I'm going to go ahead and order the kit. Looks like a reline will be in the future for my shoes.
| | | | | Joined: Jul 2014 Posts: 4 New Guy | | New Guy Joined: Jul 2014 Posts: 4 | thank you 3B for the info about the rear brake shoe spring I've been searching hi-lo couldnot find them anywere . Raybestos p/n H9223 . . broken rear spring 50 C-60
