1 members (Tronman),
60
Mod | | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 56 | My front fenders have a few dents and dings and will have to be repaired. They also have some fairly heavy surface rust. I was planning to have them media blasted but am unsure of the order of repair. Should I work the metal then blast and then prime or the other way around, blast prime then work the metal. Seems to me it would be easier to work the metal after it was cleaned up. Also I listed my truck in the Gallery but I havent seen it yet. Geo. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I would work the dents first. Use a body file to see all the high and low spots. The rust helps with the contrast. Clean it up before you weld or fill though.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2004 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 56 | Thanks Josiah, I will use your tip of the body file. Geo. | | |
