2 members (49nut, Otto Skorzeny), 84 guests, and 4 robots.
Topics128,087
Posts1,056,337
Members48,442
#103900 11/07/2004 2:25 AM
My front fenders have a few dents and dings and will have to be repaired. They also have some fairly heavy surface rust. I was planning to have them media blasted but am unsure of the order of repair. Should I work the metal then blast and then prime or the other way around, blast prime then work the metal. Seems to me it would be easier to work the metal after it was cleaned up. Also I listed my truck in the Gallery but I havent seen it yet. Geo.
#103901 11/08/2004 8:02 PM
I would work the dents first. Use a body file to see all the high and low spots. The rust helps with the contrast. Clean it up before you weld or fill though.
Paint & Body Shop moderator
#103902 11/08/2004 9:10 PM
Thanks Josiah,
I will use your tip of the body file. Geo.
