10 members (Gray_Ghost, RoadsScholar, 55shaker, Ponchogl, fonz8261, Guitplayer, Cletus1950, Otto Skorzeny, carbking, Greg_H),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,131 Posts1,056,721 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 31 Member | | Member Joined: Nov 2001 Posts: 31 | Is there any strong reason to sandblast the chassis? I am planning to degrease, sand and then go with Corroless and Chassis Black from Eastwood. I am wondering if the hassle of getting the chassis to and from the sandblaster is needed for a daily driver?
Thanks! | | | | | Joined: Feb 2001 Posts: 41 Member | | Member Joined: Feb 2001 Posts: 41 | There are lots of different techniques and opinions on this, and there is not really a right answer. My opinion is that you don't need to sandblast if you are using a rust sealer like Corroless. You just need to get off loose rust, dirt, and grease. If you go through the trouble of having it sandblasted, you might as well have it powder coated, or use a good bare metal primer (see this post for more on that). Ed | | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | I have ya a tip for removing all that caked on greese a dirt. Iam doing the samething. I had a lot of dried on, caked on greese and dirt I use purple de-greaser 2500 psi pressure washer. What worked best was Paint stripper. I use the Kleenstrip in the Gold can from Home Depot. Brushed that all over let it sit about an hour the Pressured washed againg it all came right off. Hope this helps
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | I've used Strypeze to clean them up and then used tractor paint after a primer/sealer rust converter base. The Jeeps we did are long gone but the paint is still on the barn floor! That's after 15 years. | | |
