2 members (Tronman, 50wudy), 168 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
I have a casting number of 3835590, pretty sure it is the right intake manifold. But it has a larger than normal attachment for vacuum. The male portion is screwed in to manifold per normal, the female where you would attach a hose to it are not NTP, just a bit larger than 1/4" NTP. Possibly compression? What would that thing be? Better question, how would I hook up original vacuum WS wiper motor? Am I better off to take it out and get a standard item, and where would I find one?
1955 1st Series 1/2 ton
My 235 has an elbow with a slip tube extending from it. No hose barb or fitting. If I had vacuum wipers I would use a canister to buffer the vacuum and I would be looking for the double action fuel pump to supplement the vacuum. Just use a hose clamp to secure the line and you should be OK.
Steve H
take it out and go to a plumbing supply store to find something appropriate to fit - if nothing there, check the auto parts stores, as Steve says, commonly the wiper hose is attached by clamping
The larger hole in the intake manifold may be to accommodate a line nut which holds a very short section of 1/4 inch steel line (just like brakes). Rubber hose is slipped onto the steel line and clamped.
Lots more pictures
The larger diameter vacuum line hole in the intake manifold was probably for/from a truck with a hydrovac and a 2-speed-rear selector and wipers, or there might have been a larger vacuum hole in later manifolds?
I have some steel or brass vacuum wiper fittings that fit that larger hole, and some brass fittings for the larger trucks that used hydrovac and 2-speed-rear that fit the larger hole.
A brass reducer adapter should be available at an auto part store or a hardware store.
I'll post photos, if that would help.
Tim,
pictures always would help. I tried brass in the outlet of the insert, it isn't NPT. I suppose compression. Makes sense if it was going to brakes or something more safety related. I may be able to get a compression / NPT reducer. Really, my biggest issue is I am trying to keep this thing as "correct" as possible. And I know that if I don't have this right, it is going to bug the crap out of me. I would really like to get right part that screws into the manifold for the truck its on.
Here is a quick-and-dirty web page that shows the intake manifold with 1/2" NPT hole (same GM part number as yours). Also shown are various fittings that I have accumulated (they are not for sale) and some images of fittings that would work with the wiper vacuum hose.
Make sure the hole in your manifold is 1/2" NPT (it most likely is).
NAPA and Grainger should have the brass fittings (or, be able to get them).
If you have a fitting in your manifold, you might be able to find a brass barb hose adapter for your vacuum hose.
Are all of those "standard" issue? I have the one at the bottom of the picture, I guess it is 1/2" NPT x compression?
You think this would fit as a one part replacement?
http://www.ebay.com/itm/380863173244?_trksid=p2055119.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT
I should probably just get a brass 1/2" plug and some copper pipe and make one.
I just had to deal with the same. The 235 manifold I found here on the site had a 1/2" solid plug, and I am far away from proper parts. I found a short section of former steel gas line, bent 90 degrees. I drilled a hole in the center of my 1/2" plug and glued in the gas line with JB Weld. Then rubber line to the wipers. It works so far.
Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
As far as I am concerned, anything that looks like it might have been done on the farm with whatever is at hand is "correct."
1953 Chevy 3100
1960 Volvo PV 544
Now that's the spirit I can relate to! Many of these trucks were used as farm implements that kept the farmer out of the weather.
8.963 Tube & pipe fittings (2 pages)
http://chevy.oldcarmanualproject.com/parts/1929_54/479.htm
3.278 Fittings, manfold, wiper & power brake
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0267.htm
10.154 Fittings, windshield wiper pipe
http://chevy.oldcarmanualproject.com/parts/1929_54/523.htm
16.066 Connector, windshield wiper pipe
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc1054.htm
-Tom
1950 Chevy 3100 w/ 1956 235
Just a follow-up on this topic and some observations spread over a few trucks.
On a couple 1/2-tons I have also seen this vacuum fitting, I believe it was also common to several 1950's Chevrolet/GM car applications.
https://www.flickr.com/photos/advance-design_parts_co/8603092624/in/set-72157633120087261
https://www.flickr.com/photos/advance-design_parts_co/14527050614/in/set-72157631868452754
On the one I have it is stamped with an Old English FP.
https://www.flickr.com/photos/advance-design_parts_co/11593841635/in/set-72157631868452754
The small one, the same shown in Tim's post I have also seen installed in 1/2-tons all on it's own. This piece is a Weatherhead stamped fitting.
https://www.flickr.com/photos/advance-design_parts_co/8255584995/in/set-72157632199330381
The last heavy plug as shown in Tim's I have commonly found on 3/4 and 1-tons, I think the larger manifold hole on these trucks was most likely to make the 213 Series of Hydrovac options easier to install.
The last version on the HD trucks are usually routed to the valve on the firewall for the Hydrovac/2-speed application I have seen a few different styles but don't have many pictures of them
https://www.flickr.com/photos/advance-design_parts_co/8130506223/in/set-72157631870734114
