2 members (Hotrod Lincoln, 1955 1 Series), 231 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#1037051 06/22/2014 2:35 AM
1956 Chevy School Bus Superior Body
fclaridge #1037437 06/24/2014 12:34 AM
Looking good Fred. We have to get together some time and share project progress stories and ideas. The Bulldog has a completely rebuilt front axle suspension steering and brakes since you saw it last.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
fred
what did you torque the axle bolts to? the 4 under the axle on each side
thanks
Chris
51 chevy coe
Chris,
Check out this web site for U-bolt torque info
http://www.autoandtrucksprings.com/pages/U-Bolt_Torque.html
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Grant, yes we should get together. Haven't seen you in a while. Chris, I haven't torqued them yet and Mike B, that's a great link to that information. Thank you. Now to get my hands on a torque wrench that big. LOL
Fred,
Thanks much for the link.Important info.
Chris
I'd like to know more about your axle and disc brake setup. I'm rebuilding a 1948 1.5T farm truck, and would like to upgrade from what is under it now. All brake cylinders are beyond rebuild, so I'm looking at some $$ any way I look at it.
fclaridge #1077100 01/04/2015 12:07 AM
I used axle that was already set up with disc brakes. It came out of a late model HD3500 dually. The spring pads were about 3/8" different from the original so I just widened the alignment hole about 3/16" on either side. The pad was also set up for a wider leaf so the U bolts wouldn't quite fit. Just due to the corners of the pads basically. So I cutoff to the corners of the pads and it works fine. I had a local hose shop custom make a hose that connected the original brake line to the new axle. The new flex line was made longer to accommodate the different mounting location. I did not need to do any mods for the shocks, as those are integrated with the U bolts and frame mounted. Now with the disc brakes and a taller set of gears, going from 6.17s to 4.63s, I'll have a better ride and easier cruise.
And offtopic, I'm putting in a TH400 from and RV and I just acquired, for $50 (yes Fifty), a scrap Stepvan with the disc brakes in the front that has the 5-10 lug pattern and 19.5 wheels. I'll use the front spindles and brake hardware to convert the front brakes to disc as well just like Grigg's Tech Tip. Which is brilliant by the way. The local spring shop will custom make a set of bushings to match the kingpins off the bus and the spindles off the Stepvan. Then just hook up a brake line or two and that's done too.
fclaridge #1077569 01/05/2015 11:56 PM
Lookin' Good! --- I see we went the same route (Dana 80HD) on rear axles for our buses. I wound up getting a new set of lighter rear springs in the hope of softening the ride a bit. Only difference on the front is that I am going to try out Randy Domeck's disk kit. I am looking at mounting the Hydroboost & Master from the same C3500 under the floor since I have no room left under my narrow-nosed '46 hood.
I'm guessing you have a lot more room than I do so what are you doing in that department?
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
I just rebuilt the original springs for the rear. It still sits kind of tall, but later this year I'd like to get wheel adapters and put on some modern 22.5 wheels and low pro tires. That should make it look good. So knowing that I did not do anything to change the springs and have to spend the money all over again. I am going to use the Hydrovac I have in there that has been rebuilt and fabricate a bracket to accomodate a more modern larger bore MC. I think with the suggestions I got from some guys here about the HV was good info so I'm going to keep it in and make sure I have it set up right.
