1 members (klhansen), 92 guests, and 1 robot.
Topics128,049
Posts1,055,741
#1036135 06/17/2014 4:31 PM
This truck air cleaner looks like mine (standard flat 40s truck) but different base, which is recessed and decal is dark blue vs. the orange repops. I'm guessing it's very early or not truck at all.
Anyone!
http://www.ebay.com/itm/201104643559?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
1946 1/2-Ton Chevy
I am guessing it is still trucks as I just don't see these on cars much unless people have added a second carb. But you are right on the base, might have been for clearance issues. Here is the one most commonly seen on AD's.
https://www.flickr.com/photos/advance-design_parts_co/8250844197/in/set-72157632186114015
Brad, The only clue I have is an ad for this shorty stating early Corvette but? I have seen pics of 53-54 Vettes with these used with a different top, but cannot see the bottom side. For years the Vette collectors would buy up the truck units to use. 53 Vettes used three flame arrestor type, next year two like these, but feeding the three carbs.
Also I believe the dark decal is an earlier version.
1946 1/2-Ton Chevy
May be on to something with the Corvette application. Did a little research and it seems like it was a late 54' application? Also makes sense due to clearance issues on the vette. I bet the pictured set-up below especially if it was limited application run is a fairly rare item.
https://www.flickr.com/photos/advance-design_parts_co/14258907690/in/set-72157631868452754
The decal may indicate it was sourced from existing parts bins for the Corvette as they took parts from all kinds of stuff for the early ones. It may have been used in another application finding out exactly which one is the puzzle piece.
Appears even this display motor has the truck air cleaners, top and bottom. I know for sure the 54 vette units used a smooth top. Believe I've seen this engine in the past poss. GM display piece.
1946 1/2-Ton Chevy
1946 1/2-Ton Chevy
403 error on the link Jimerit
Redryder pix
My Hotrod
The air cleaner on ebay appears identical to the one that came on my 1941, base, decal, and all.
Does anyone know where to get a replica of that decal?
