| | | Forums66 Topics128,164 Posts1,057,081 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | About 10 months ago I took the seat that was in my 57 when I bought it, to the upholstery man. He did a beautiful job on it for $200 He made it 2 colors and rolled and pleated inserts for the bottom and back.
Now, I am terribly disappointed since I have installed it. I am wondering if it came out of something else. The back hits the curve in the back of the cab and will not go back far enough to be comfortable. It likes 2 or 3 inches hitting the cab below the rear glass. But I have wedged it in the curves as far as possible. Could someone give me a rough measurement of the length of their seat back on a 55-59 model? Thanks very much.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe you're just some bigger than folks were back then  55.5" outside to outside of the arms that the back mounts on - notice that those 'hinge' arms rest on adjustable bolts that are in brackets that stick out each side - the adjusters set the vertical angle of the back, and the brackets those bolts are in are frequently twisted/bent down/broken by years of abuse .... my seat all the way back on the tracks leaves a couple/few inches to the back wall without hitting anything .... the LCF shouldn't really be different there, see if you can adjust the back angle Bill | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Thanks Bill. I will try that. I think I am about average. 5ft. 10 inches. 170 lbs. I do have long arms and this thing has a huge steering wheel. I guess it is larger than a pickup.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Thanks for the measurement Bill. I do have the wrong seat. Mine measures 60.5 at the back arms. Must be out of a 60's model? Now I have a beautiful gray & white seat I cannot use. Got to start looking for an original seat now.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Thanks to all for the info. and measurements. I got lucky and found a seat out of a 1955 here in town. There is 5 inches difference in the width of the seats. (No wonder I couldn't install it.) I already got it back from the upholstery man and put in the truck. I can drive it now!! Since I was at it, I changed the color scheme from white & gray to turquoise and gray. Turned out beautiful and no white to get dirty off the seat of my pants!
