| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Here's another question regarding newly installed 235. I filled the tranny with gear oil after installation. Today when rereading the shop manual I noticed that in the section about installing the engine (in a half-ton) it says to remove the speedometer gear and fill the rear-most part of the tranny with 1 1/2 pints of gear oil, to lube the universal joint. So I did this, it took a whole quart of oil. There is nothing about this in the section about installing just the transmission. Have I misunderstood something? Do we need to fill two sections of the tranny?
Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The U' joint section just needs a little for initial lubrication. Once the transmission is put in use it is kept full from the oil in the main case migrating back to it. If you over filled the U' joint area the main case will end up over full.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | The book (engine installation) says add about a pint, so I guess that gearbox is full. It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I'll drain some from the main box tomorrow. It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I just filled my tranny, ball joint yesterday. I found in the service manual to fill the ball/u-joint area with 1/2 pint of gear oil via the pipe plug at end of tail shaft. Which I did. I filled the transmission with oil until it ran out of the fill plug.
So, what is correct. 1952, 3 speed | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Level with the hole when it's warm, 1/2" below when cold. Your pinky finger should just be able to touch it cold when you hook the first joint over the edge. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0005.htmAfter a refill, check it a few times after you run it till the level stabilizes. Denny G
Denny G Sandwich, IL
