2 members (dt235sd, 1 invisible), 355 guests, and 4 robots.
Topics128,154
Posts1,057,015
Members48,460
#1034141 06/07/2014 9:17 PM
Here's another question regarding newly installed 235. I filled the tranny with gear oil after installation. Today when rereading the shop manual I noticed that in the section about installing the engine (in a half-ton) it says to remove the speedometer gear and fill the rear-most part of the tranny with 1 1/2 pints of gear oil, to lube the universal joint.
So I did this, it took a whole quart of oil.
There is nothing about this in the section about installing just the transmission.
Have I misunderstood something? Do we need to fill two sections of the tranny?
Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
The U' joint section just needs a little for initial lubrication.
Once the transmission is put in use it is kept full from the oil in the main case migrating back to it.
If you over filled the U' joint area the main case will end up over full.
My Blog
The book (engine installation) says add about a pint, so I guess that gearbox is full.
1953 Chevy 3100
1960 Volvo PV 544
I'll drain some from the main box tomorrow.
1953 Chevy 3100
1960 Volvo PV 544
I just filled my tranny, ball joint yesterday. I found in the service manual to fill the ball/u-joint area with 1/2 pint of gear oil via the pipe plug at end of tail shaft. Which I did. I filled the transmission with oil until it ran out of the fill plug.
So, what is correct. 1952, 3 speed
Level with the hole when it's warm, 1/2" below when cold. Your
pinky finger should just be able to touch it cold when you hook
the first joint over the edge.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0005.htm
After a refill, check it a few times after you run it till the
level stabilizes.
Denny G
Denny G
Sandwich, IL
